1 - 20 of 21 Posts
hrmm<p>has been happening once in a while...<p>i dont think it has anything to do with the wastegate adjustment, because i had it a few times before that too. at first i thought i went over a rough part in the road... but i have been checking and it wasnt.<p>what could cause this? it is like the engine isnt getting enough fuel or sumthing, or is really cold.<p>i have my car set to economy mode usually and sometimes i do hard acceleration from a stop but i only go up to 40/45 until i let off. i always let my car get up to temp before any hard acceleration is done, and my oil level seems fine.<p>any ideas????
Re: Engine Stutter (GShyneDM)
I know what ya mean. even when not moving, actually, usually when stopped at a light or something, there's a lil rumble in the engine bay, like the engine wants to shut off, then it goes right back to normal. I'm guessing it's from the turbo timer or whatever, like it turns on and takes away from the rest of the cars power till it generates more power. Anything close to what you're talkin bout'? For like a split second right?
Re: Engine Stutter (biggerhurt38)
I have had the problem and just thought it was the sweedish A/C? just my thought...if yall have the same thing as i sometimes expierence..
<BLOCKQUOTE>quote:<HR>I know what ya mean. even when not moving, actually, usually when stopped at a light or something, there's a lil rumble in the engine bay, like the engine wants to shut off, then it goes right back to normal. I'm guessing it's from the turbo timer or whatever, like it turns on and takes away from the rest of the cars power till it generates more power. Anything close to what you're talkin bout'? For like a split second right?<HR></BLOCKQUOTE><p>yeah!! exactly!!! thats what it is like. glad to hear i am not the only one with this problem.
Re: Engine Stutter (C70 MATT)
<BLOCKQUOTE>quote:<HR>I have had the problem and just thought it was the sweedish A/C? just my thought...if yall have the same thing as i sometimes expierence..<HR></BLOCKQUOTE><br>i rarely ever use my A/C.... usually windows down is enough.
That makes three. I have the same problem as well. I shrug it off now since I got used to it. I thought it was the ABS doing a self check but it;s coming from the engine.
Re: Engine Stutter (mike_c70)
ok well other possibilities <br>1) computer injector pulses or <br>2) the fan turning off and on, causing the shaking or <br>3) or anything that eats up amps like the ECU cycling on and off <br>I wouldn't worry about it though <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0">
I had that problem, but a little more extreme, it turned out to be my distributer, and that the number 2 and 4 cylinders were missfiring a little bit. I took it to the dealer, they replaced and everything is running great now.
Re: Engine Stutter (mtbman11)
<BLOCKQUOTE>quote:<HR>I had that problem, but a little more extreme, it turned out to be my distributer, and that the number 2 and 4 cylinders were missfiring a little bit. I took it to the dealer, they replaced and everything is running great now.<HR></BLOCKQUOTE><p>hrmm.. perhaps i should get my distributor changed, along with the plugs and wires.<p>maybe my minor stuttuer is the beginning
<BLOCKQUOTE>quote:<HR>I had that problem, but a little more extreme, it turned out to be my distributer, and that the number 2 and 4 cylinders were missfiring a little bit. I took it to the dealer, they replaced and everything is running great now.<HR></BLOCKQUOTE><p>What did they change? Maybe I should look into it as well.
Discussion Starter · #13 ·
<BLOCKQUOTE>quote:<HR>I believe they replaced the distrubutor and wires.<HR></BLOCKQUOTE><p>how much did they charge you?<p>ipd sells the distributor cap with plugs and rotor for 60 bucks
Discussion Starter · #14 ·
<BLOCKQUOTE>quote:<HR><br>3) or anything that eats up amps like the ECU cycling on and off <br>I wouldn't worry about it though <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0"> <HR></BLOCKQUOTE><p>hrmm.. i know i have my music pumpin & all lights on (int & ext)<p>maybe i'm sucking up all the power <IMG NAME="icon" SRC="http://********************/smile/emsmilep.gif" BORDER="0"> time to get HID that uses up less power <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0">
They didn't charge me anything <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0"> I guess it was an abnormal problem, so it was under warranty.
Discussion Starter · #16 ·
<BLOCKQUOTE>quote:<HR> They didn't charge me anything <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0"> I guess it was an abnormal problem, so it was under warranty.<HR></BLOCKQUOTE><p>thats cool... i should check about that then..when i go in for 30k tune up
Hay Gshyne before you check the distributor ask the dealer to look on all the engine mounts. They brake and cause a vibration that sounds pretty bad. That was my first problem on my car got both of them replaced the top and the side and it fixed the problem....never heard it since..plus its under warrenty for that!!
Re: Engine Stutter (C70SPEED)
bye they way the noise is more at a stop than driving for some reason I also thought it might be from my distributor but my mechanic noiced it right away.. You can check on this by when the car is parked open the hood and look on the engine mount it should be located at the top of the engine and connets to the front of your car move it from left to right if it moves then that one is bad. the others are harder to get to they are down in the sides of the car.. but ask them to check that first..
Discussion Starter · #19 ·
<BLOCKQUOTE>quote:<HR>bye they way the noise is more at a stop than driving for some reason I also thought it might be from my distributor but my mechanic noiced it right away.. You can check on this by when the car is parked open the hood and look on the engine mount it should be located at the top of the engine and connets to the front of your car move it from left to right if it moves then that one is bad. the others are harder to get to they are down in the sides of the car.. but ask them to check that first..<HR></BLOCKQUOTE><p>good call.. i had them checked last month when i had a clinking of somesort... they said everything was fine, all the mounts, etc..<p>so i dont think it is that. maybe it is.. i'll have them check again...
do you know if they lifted the car in the air cause the other mounts cant be check from just looking you have to raise the car.. Bye the way its better to make sure those mounts are not broken the engine cannot move..
1 - 20 of 21 Posts
