1 - 12 of 12 Posts
I will be in the market for a new engine in the coming months. anybody have info as to the newest engine that will drop into the 98 v70?
Brad
98, unless you want to do some major mods and part swaps
99 and newer (ME-7 engines) are very different.
It's been done of course but it's a royal PIA
You do have access to V70R engines, 850R/Turbo engines and X70 GLT engines all of which are nearly indentical in their outward appearance and part compatibility.
1998 V70 T5 with factory m56h; 18t, Green injectors, 50% e85
The newer "RN" engines from 2000+ S60/V70s are a real option for you. They are widely available, reasonably priced, offer performance/efficiency advantages, and there is a growing knowledge base about how to install them in the <2000 cars. http://volvospeed.com/vs_forum/topic/152415-01-engine/page__pid__2077945#entry2077945http://volvospeed.com/vs_forum/topic/146623-the-unofficial-rn-block-swap-how-to/page__hl__turbo+parts+swap__fromsearch__1 http://volvospeed.com/vs_forum/topic/154256-rn-motor-install/
+1 to Mitch's statement about the RN engines. They are the way to go if you plan on further modifying the car after you swap the engine.
The newer "RN" engines from 2000+ S60/V70s are a real option for you. They are widely available, reasonably priced, offer performance/efficiency advantages, and there is a growing knowledge base about how to install them in the 2000- cars.
He said INTO A 98... not a 2000. This is a very different engine and is problematic
Into a 2000 is easy
Jim, swapping a newer motor is not as hard as it has been described in the past. There are a large number of cars on here and Volvospeed (probably MVS too) with RN engine swaps. It requires a few modifications to the longblock assembly, but it is far from impossible to do.
In short, to install a 99+ engine("RN") in a -98 car ("N") you need to drill the intake cam to accept the distributor plate and CPS, use the pre-98 intake manifold, change one engine mount to a newer style, and use the RN accessory bracket and alternator, ps pump, etc.
There are a few more steps, but that is the gist of things.
FWIW I put a GLT motor into my R, but used the turbo, the injectors and of course the ECU from the R motor. Car is now faster than stock. and it was all plug and play. Depends on how involved you want to get.
I never said it was impossible but it IS hard, nothing fits
I worked on Adam's car over last winter, nothing latches up. You're dealing with a non CVVT engine vs a CVVT motorl ets
Sensors are all different. Accossories all bolt on differently, etc
Cam cover doesn't fit and more
Into a 2000 is easy
Could be into a 98, 97, 96, 95 . . . . all doable, with some mods, which are becoming well documented now. The o/p asked "what's the newest engine" that can be "dropped in". Maybe that meant plug-n-play, but he clearly wants to use newer components if possible, so given the options, he can figure out what direction he wants to take.
2.5t to 2.3t swap
So I need a motor and I was reading that I can use the 2.3t instead of the 2.5t, is that correct? Direct bolt on? I have a 2006 2.5t xc90 and I want to install a 2.3t from a 2002 s60, does anyone know if they will work? And I just have to get the ecu tuned right? Please help me with this. Thank you
"Work" yest but you'll always have a code for the missing intake vvt solenoid unless you swap the head.
You'd be better of to put in a 2005+ T5 2.4 B5244T5 or R 2.5 B5254T4. Those will be bolt ins and wire up's.
1 - 12 of 12 Posts
