Re: Engine Mounts. How difficult a job? (Poritz)
I have never done the job, however...<p>The procedure is not difficult, but it is grunt work. You will need to jack up the engine, unbolt the mounts, put in the new ones, and here's the tricky part, get them to line up correctly so everything goes back together. You can jack the engine by the oil pan, but it's recommended strongly to use a block of wood to spread the load. If the oil drain plug is in the way, drill an oversize hole in the wood to clear the plug. Jacking by the oil plug will cause damage.<p>Your car uses hydraulic mounts, which are expensive compared to the solid rubber mounts used on older models. Look to see if they are sagging or broken. Rev the engine to see if it moves a lot. Excessive vibration through the steering wheels is usually a symptom of worn motor mounts.<p>Good luck. See my links page if you need a source for new parts.
