1 - 12 of 12 Posts
Hi, I have a friend who's 740 2.3 starts up ok and runs for about 2/3 miles and the cuts out, it won't start again until you toe the car a few yards or its been sat for a about an hour, then fires up and runs for a while, then cuts out again, doesn't seem to be a spark at the coil? Fuels ok, any ideas before I replace the E.C.U<br>thanks Stuart <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: Engine cuts out (Stuart.br)
Welcome to Swedespeed, Stuart.<p>Your email is UK and you are in Spain - where is the Volvo and friend?<p>Below is the link to 740 fixes including mass air meter problems and faulty fresh air thermo/flap as this could cause the described symptoms.<p>George Dill<p><A HREF="http://www.brickboard.com/FAQ/700-900" TARGET="_blank">http://www.brickboard.com/FAQ/700-900</A>/<p>
Hi, I'm in Spain and so is the volvo, can they real cause these problems? Air is near the air filter, right? fresh air thermo/flap is where? thanks George
Re: (Stuart.br)
The thermo and flap are in the fresh air box with the air filter.<p>The mass air meter is in the duct (hose) between the air filter and (dirty?) throttle body.<p>George Dill
You say the fuel is okay, but the problem you describe seems to be a fuel system problem.<p>I would first change the fuel filter.<p>Then, check the fuel system relays.<p>Then I would move on to the Air Mass Meter. I wouldn't think the fresh air flap in the air box would cause that kind of problem, but I've been wrong before.<p>You could also have an overheating ignition relay, but that's a different set of problems.<p>Does the car slowly die? Or just completely stop running.<p>When it restarts does it restart quickly and easily or does it sputter to life?<p>Thanks and I hope this helps.
Re: Engine cuts out (CarlieBentley)
I have a similar, if not a same problem. My car won't start again after I have driven it a while (only when the weather is hot, like over a 90 degrees, especially when it is humid) until I open the hood for about a minute or two. <br>Then it will restart immediately, without sputtering or anything.... the car is not overheating,. I have had this problem for almost a year, but since it only happens in hot weather, it was impossible to realize that it had not been fixed until now. <br>The mechanics think it could be the battery connections, or a relay switch. <br>The fuel relay switch? <br>Do you have any suggestions for me? <br>Thank you very much.<br>Ilse
Re: Engine cuts out (gdill2)
760 1990 <p>I was just told by a friend that it could be the fuelpressure regulator, and the gas filter.<br>I had the battery connections cleaned. Problem persists.<br>Any suggestions?<br>Sorry I waited so long to reply.<BR><BR>
<i>Modified by blitzmesser at 4:46 PM 6-20-2006</i>
Hi,<br>I was just reading the quick reference guide: Hot start Problem Diagnosis.<br>Both questions assume that the engine cranks... <br>in my case the engine spins without a sound, (there is no cranking), but once I open the hood to cool it for a couple of minutes), it turns over right away and behaves normal.<br>Would I look for a solution under section 1 or section 2 ?<br>Thanks,<p>Ilse
Thanks George.<p>What are the symptoms of solenoid failure ? Is the starter solenoid affected by heat? <p>I just read in the FAQs that someone with a similar situation discovered that the problem was in the Power Stage..<br>He cleaned the contacts and coated them with dielectric grease, then coated the heat sink with a thermal compound... and the problem did not come back.<br> .. where is the "Power Stage" located? <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: Engine cuts out (blitzmesser)
I just read more of the FAQs and understand where the Power Stage is and what it is.<br>What do you think of the solution to coat the heat sink side with a thermal compound? (What is a good thermal compound?)<br>I am not a mechanic whatsoever, don't even know what is what, but I am learning through the FAQs.<br>I have spent so much time and money on having problems fixed, only to get the car back with the same problems, that I have plans to find some solutions for myself. <br>Thank you for your input!!!!<br> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>Actually: my engine does not cut out. I never loose power. Once I stop the car and turn the motor off, I cannot restart when the weather is hot. I have to open the hood for a couple of minutes, or wait a few hours.
1 - 12 of 12 Posts
