Hi, Does any know know to fix code Engine Cooling Fan Error Code?
I swap my cooling fan from year 2001 to cooling fan R model because it's bigger fan but after that I got the error cooling fan code. However the cooling fan still work as normal except the error code showed up.
Does anyone know how to fix it? I think about to swap back to the original cooling fan if I cannot find the way out
<img src="https://i.ibb.co/cQNc3FS/1565404488629.jpg" alt="1565404488629" border="0">
Use the control module from your other fan on the "R" fan. (it IS the relay etc..)
Do you mean use the old relay control module from original cooling fan with the R Fan? Need some modification? Because it's different type.
