1 - 2 of 2 Posts
engine light came on the other day and i ran the codes in A2 and got a 315 which is supposed to be a problem with the EVAP system. any clues on where to start?<br>nathan
Re: engine code 315 (zj)
I had this problem a year or so ago. It is most likely the EVAP valve (aka purge valve). It's located near the top of the radiator on the drivers side. If I remember right the part was about $35. It's an easy 30min. job to replace. BTW, my car's on it's third one.<p>Other possible causes include a vacuum leak in the system or a bad charcol canister.<br>
1 - 2 of 2 Posts
