1 - 6 of 6 Posts
Any body have a good engine cleaner recomendation? This thing isn't a sludge pit or anything, just needs a good engine compartment detailing.
Thanks Rich
WD40 is a very effective degreaser, used with a couple 1" wide cheap paint brushes. Cut the bristles short on one brush so you can scrub the tough spots with it.
Thanks Rich
Share your intended wash procedures including rinse and runoff then I'll offer up some products.
Thanks.
George Dill
Thanks.
George Dill
I was gonna use a "spray & leave on" type of product, like seafoam or gunk foam degreaser,..I'll just rinse it off on my,driveway.
Good show - just don't drink the water in your downstream community.
Try simple green® All-Purpose Industrial Cleaner/Degreaser just be sure the engine is not real hot. This product is bio and can be added to the storm runoff with minimal damage to the environment...
http://www.amazon.com/simple-All-Pu...reaser/dp/B000M2SHHO/ref=cm_cr_pr_product_top
Top-rated degreaser...
http://www.amazon.com/simple-All-Pu...ummary_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Rinse the engine with a very fine spray then wash everything down the driveway, out into the street then down the gutter.
You might want to pre-spray any grease spots on the driveway to take advantage of the cleanup.
George Dill
1 - 6 of 6 Posts
