My '66 does not use this support bracket. The bell housing is structurally attached with bolts that go into the back plane of the block only. I am assuming this bracket was used to strengthen that joint so that the bottom bell housing bolts would could transfer load to the 4 oil pan bolts. Is this correct?
If so, is there any advantage to having one of these brackets and could I use on my '66 with a later model bell housing which I received with an M41 I'm rebuilding and will install this spring? That is to say, if I have the correct bell housing, will my '66 B18 block/oil pan take accept the bracket?
Thanks in advance for any insight/recommendations.
Mike Rains
Charlotte
Mike Rains
Charlotte
