1 - 20 of 26 Posts
I've been wondering what is wrong with my right rear brake. Since the day I washed it and left it in the garage, when I drove it the brakes were stuck to the rotor. I stepped on the gas and broke it free. ever since then the right rear brake has not been the same. I drove it on a road trip and noticed the wheel was dirtier than the front one (very unusual). When I release the e-brake and drive it in reverse sometimes I hear a loud popping sound. <p>I've removed the caliper and noticed nothing wrong with my pads.<p>Any ideas?<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>I am driving to Little Rock, Ar and then to Houston, Tx and back to Mississippi this weekend. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: Emergency Brake (sinisin63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>sinisin63</b> »</i></TD></TR><TR><TD CLASS="quote">I've been wondering what is wrong with my right rear brake. Since the day I washed it and left it in the garage, when I drove it the brakes were stuck to the rotor. I stepped on the gas and broke it free. ever since then the right rear brake has not been the same. I drove it on a road trip and noticed the wheel was dirtier than the front one (very unusual). When I release the e-brake and drive it in reverse sometimes I hear a loud popping sound. <p>I've removed the caliper and noticed nothing wrong with my pads.<p>Any ideas?<br> :confused<p>I am driving to Little Rock, Ar and then to Houston, Tx and back to Mississippi this weekend. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> </TD></TR></TABLE><p>E brake is actually a drum type brake that you cannot see untill you remove your rear rotors, all will become fairly obvious after that <p>
I have the same problem on my V70R after washing. As with you, my right rear parking brake locks up. The service brakes can be fine, but the parking brake locks to the rotor. Too bad you didn't pull the rotor off when you had the caliper off. You're going to have to go back and pull the rotor off before your weekend trip. If I remember correctly, a 10 mm bolt holds the rotor onto the hub. After washing my car, I now park in the garage with the parking brake off, and a pair of wheel chocks to keep the car from going anywhere.
Re: Emergency Brake (xman03)
I second that (replacing the shoes that is). I also heard the odd crack when backing up over the last few weeks, and a tendency for the e brake to engage later when pulling the handle. Long story short, yesterday I was driving to work when I heard a loud crack, followed by scraping noises and heavy vibrations felt through the steering wheel. Had to be flat bedded to the dealership, whi gave me the verdict that the shoe had come apart and had lodged in the wheel, shearing off any number of components before I could stop the car. Total damage $1,700+ (car is still in the shop), so I know I'll be very alert to any changes in handle play or strange noises going forward...
Re: Emergency Brake (MAC1LSR)
I'll definetly tear into it this weekend again before I head out. I was hoping to find something wrong with the brake pads in the caliper but I know for sure it is the e-brake. I just don't know how to take the rotor off but it can't be too hard for this aircraft mechanic. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
Re: Emergency Brake (petew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>petew</b> »</i></TD></TR><TR><TD CLASS="quote">NEVER NEVER NEVER, use the emergency jack <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> </TD></TR></TABLE><p>can you further explain this one? i was having trouble the other day jacking the car up completely on both sides and balancing it so it didn't tip over, since the jack points are so weird
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>sinisin63</b> »</i></TD></TR><TR><TD CLASS="quote">I've removed the caliper and noticed nothing wrong with my pads.<br> </TD></TR></TABLE><p>Also, please read the DIY about brake pad replacement. You only need to push out the 2 pins holding the metal spring pressing on the pads. After that the pads lift out, without removing the caliper.<p>Just making sure your aware to save you time in the future <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: Emergency Brake (jstro)
I've removed the wheel and caliper but I can't seem to take the rotor off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>I took the bolt off that's in the middle and the littlt bolt but still nothing.<p><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/RoofRack02.jpg" BORDER="0">
wrong picture submitted earlier<p><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/IMG_0981.jpg" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>sinisin63</b> »</i></TD></TR><TR><TD CLASS="quote">I've removed the wheel and caliper but I can't seem to take the rotor off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>I took the bolt off that's in the middle and the littlt bolt but still nothing.<br></TD></TR></TABLE><p>Put the big bolt in the middle back - take out the little one along with the caliper. You have to break the rotor loose with a hammer/mallet. If you're replacing the rotor, just use a hammer, if you're re-using the rotor, use something that doesn't dent it, like a piece of wood between it and the hammer <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: Emergency Brake (S60R1)
E-brake shoes and springs should be replaced every ~3 years or so <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Discussion Starter · #14 ·
I've been hitting it pretty hard with a block of wood too. I've only seen some brake dust on the floor and still no signs of breaking free. I hope I'm not forgetting to remove something else. I've taken off two bolts for the caliper and hung it, one small 10mm bolt, anything else?<p><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/IMG_1003.jpg" BORDER="0">
Discussion Starter · #15 ·
I just needed a bigger hammer! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <p>I can tell I need new pads for my e-brakes<p>Can I still drive it that way till I get some new pads???? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>I hope so.
Bigger Hammer <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> sometimes they really stick <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> It will come off with enough persistance <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Discussion Starter · #17 ·
here's a picture<p><br><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/IMG_1004.jpg" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>sinisin63</b> »</i></TD></TR><TR><TD CLASS="quote">here's a picture<p><br><IMG SRC="http://i723.photobucket.com/albums/ww237/sinisin63/IMG_1004.jpg" BORDER="0"></TD></TR></TABLE><p><br>Are thosr the delaminated pads on the ground?!!! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> <p>Good thing you are replacing them now!!
Success <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Discussion Starter · #20 ·
Re: Emergency Brake (volvosince16)
I hope autozone carries these pads. Because I've got to drive to Little Rock, AR tomorrow.
1 - 20 of 26 Posts
