I have a 99 coupe that continuously blows the #15 fuse controlling the interior and trunk lights and seat belt reminder. The problem came on while driving with the constant chiming of the seat belt reminder that I removed to stop the noise. Anyone know of a cause or fix for this problem? Thanks.
That's going to be tough to figure out, but I'd start by checking the wiring to the seatbelt latch and see if it got pinched or disconnected in such a way that it shorts out.
For the benefit of anyone who may have or get this problem, or if an electircal component that requires the key to be on stops working, the culprit was the ignition switch. After I had the switch replaced because the key wouldn't turn, all the lights worked.
