1999 V70 T5
When i start the car the speedometer dashboard light will not light up right away. The power windows will not work right away. The SRS light on the dash board will stay on a few seconds. After 5 seconds or so the dashboard lights right up, power windows work, and everything is back to normal.
car has been doing this for close to 3 weeks now.
Thank you for reading guys.
You may have a weak battery. You can get it checked at most auto parts stores. If you have a voltmeter, you can check it yourself
Checking system voltage is a great place to start.
Battery, alternator, cables and ends, etc.
If that's all looking good, I'd move on to
the ignition switch and overload relays.
Check voltage at the alternator + post and compare this with voltage at the battery. Usually there will be a voltage drop and the main cable is due for replacement.
Sent from my SM-N910G using Tapatalk
