Discussion Starter #1
:facepalm: I lowered my car with the pro kit and my car started to click while turning, I called up iPD and they said it was the endlinks going. So I Installed the HD endlinks and it still is creaking,not clicking,I talked to a senior mechanic at volvo and he said was always going to happen, any input? should I put the stock ones back on?
possibly the strut bearings are dry and creaking. see if you can lube the sways and see if it helps. it could be as far as a cv riding in a different position and be on its way out. hard to say really. when i did my hr's i had no issues. check all your bushings and lube if applicable.
Turn up the radio
I have Eibachs. Went all new parts on the install. Now it creaks at full lock in the parking lot. Nothing you can do about it but also nothing of concern, just parts rubbin together.
