1 - 12 of 12 Posts
I use 10mm Eibach spacers.These are 5mm one wheel +5mm other wheel.<p><br>I am not sure if this is the right choice.For the look not som much difference.<p><br>For rubbing with 18 pegs,decreased rubbing.<p>Would you advice me to have 10mm + 10 mm or 15mm +15mm?<p>If I have one of the above ones,what advantage does it give with springs?
Re: Eibach Spacer change... (xenophobic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xenophobic</b> »</i></TD></TR><TR><TD CLASS="quote">I use 10mm Eibach spacers.</TD></TR></TABLE><p>Where did you get 'em, if you don't mind me asking, and did you have to order lug bolts seperately?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xenophobic</b> »</i></TD></TR><TR><TD CLASS="quote"><br>For rubbing with 18 pegs,decreased rubbing.<p>Would you advice me to have 10mm + 10 mm or 15mm +15mm?<p>If I have one of the above ones,what advantage does it give with springs?</TD></TR></TABLE><p>I use 5mm up front and yes they help with rubbing but no noticeable look change. In the back I use 10mm and they do look nicer.<p>Advantage with springs? I doubt there is any, there may be the disadvantage of fender rubbing if you go 15mm each.
Re: Eibach Spacer change... (JOSBRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JOSBRO</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Where did you get 'em, if you don't mind me asking, and did you have to order lug bolts seperately?</TD></TR></TABLE><p>I bought them from Germany/Eibach directly.They also gave the longer bolts too.
I would advice you to use 10:10 or 10:15 instead of the 5 mm spacers. This mainly because the 5 mm doesn't come with the hub rings. The 10 mm spacers (20 mm axle) come with hub rings so the ring will remain better centered at all time.
This is what I use with the 10 mm per side spacer,<p> <IMG SRC="http://www.swededemon.com/images/ext/spacer/spacerbolt.jpg" BORDER="0"> <p> <IMG SRC="http://www.swededemon.com/images/ext/spacer/boltbox.jpg" BORDER="0">
Re: Eibach Spacer change... (Johann)
The spacer,<p> <IMG SRC="http://www.swededemon.com/images/ext/spacer/spacer1.jpg" BORDER="0">
what is the proper website for heico?<p>or must these be purchased through someone else?
Re: (phuz)
Heico's site:<p><A HREF="http://www.heicosportiv.de/mainframe.asp?lang=en&e1=212" TARGET="_blank">http://www.heicosportiv.de/mai...1=212</A>
1 - 12 of 12 Posts
