Quote, originally posted by juve021 » |
Please post your normal driving and peak EGT temps and list if you are tuned or not. Thanks. |
Thanks Matt. Randy, just trying to get the range for my OLED gauge so I can calibrate my thermocouple opamps correctly. |
Quote, originally posted by phuz » |
If you want tighter precision, I will do a datalog of the EGT on a full boost, full RPM run |
Its ok. I think these numbers are good enough. Just trying to find a decent range to expect. Plus, the mounting point of my EGT probe will not be at the manifold so my numbers will be off (less) than these. |
OK...these readings are actually from O2 sensor 1...which is located on the elbow of the Downpipe. |
