For an EGT probe, wheres the best place to put and the easiest way to get to it. From what I understand, the closer to the head, the better. I've read that you can drill and tap one of the runners on the manifold, but I don't see this being an easy prospect on the R.
Also, where to tap for a good oil pressure reading?
EDIT: Just found this via search.
http://forums.swedespeed.com/z...03498
From what I get out of it, you can pull the factory sensor, replace it with a T fitting and then put the OEM sensor and new gauge sensor in either end of the T?
If you can explain it to me, great. If you got pics, even better!
Appreciate the help!
Rue
Rue
