ECM-925D - Throttle Valve - Signal Too Low
14744 Views 7 Replies 4 Participants Last post by  buffaloV70R
This morning, when I went out to start the caR, I received the "Reduced Engine Performance" message. This seemed strange since I've not had any problems recently (outside of 06/07 GT Valve Body issues). I turned the caR off and immediately restarted it. No message. Drove where I needed to go (short local drive). Drove it home a few hours later. Had a longer drive planned for the evening, so I hooked up the VIDA to see what caused the message. The only stored code I got was "ECM-925D - Throttle Valve - Signal Too Low". I've not experienced any kind of goofy throttle related issues, so it's a bit weird that this would show up out of nowhere. When I read the codes, VIDA showed <30% error active, but said it reported the code because there were at some point >60% error. The only time since I've had this caR that I had anything I could have attributed to the TB was in July 2013 when I had some idling issues. At the time I did not have VIDA, so I just blanket replaced all the things that could have been involved and could use replaced anyways (BPS, FPS, MAF, Plugs, Coils, Air Filter, PCV System, ECU Relay, and had the Throttle Body cleaned). Somewhere in all of this, my problem went away and I was happy knowing my caR was that much closer to Stage 0. At the time I always sort of had in my mind that it might be a throttle body issue (don't remember why now) which is why I included the cleaning. I'm wondering now if I didn't just delay the eventual failure of the unit.
I searched and searched and cannot find anyone who says they had this code. Has anyone had this and if so, what did you do? Also, I'm assuming this may end up with needing the throttle body replaced. I think I've read someone was able to do this without removing the intake manifold. Anyone have tips on this? If I have to do it, I'd prefer to get away without having to do as much work as vLGrok did in his famous post (http://forums.swedespeed.com/showthread.php?176501).
Thanks in advance for the advice.
1 - 8 of 8 Posts
Well are both potentiometers reading 30% off? Maybe the connector is loose. It's mounted out facing the radiator fan so no digging required to check. If the ETA does need to come out I know the easiest way to pull it... Remove the intake air hose to the airbox, OTE pipe, rotate the fan 180 and pull it out... Or you can pull the entire airbox and lift the fan our directly.
Are the potentiometer readings something I can have VIDA graph?
Here's the conclusion to this post, as seen here:
https://forums.swedespeed.com/showt...r-R-today!-!&p=3781297&viewfull=1#post3781297
Finally got around to replacing the SR's throttle body. It had been getting worse. It started by very occasionally giving a "Reduced Engine Performance" message. This was easy enough to get around by just turning the key to POS II, checking to see if the message came up, and starting it up if it didn't. If it did pop up, then just shutting it back off and trying again. It was also showing a code in VIDA regarding a "Too Low" signal from the throttle module. This started as once a month, then went to once a week, then almost every time I got in the caR, then to the point that the message would not go away and started causing the throttle to react in weird ways. Months ago when the code and message first appeared I bought an almost new throttle body from CMOD knowing the problem would come to a head. I'm not exactly sure why the unit failed. I'm not sure the insides of the wiring area is supposed to have oil all through it. If anyone wants this old one for parts, let me know.
So here's pictures of the removed unit (first two just as they appeared when I opened the case, second two showing after wiping oil off with a papertowel):
Inside the throttle area:
Not bad. It was "cleaned" by the dealer at around 70k, if I remember right.
The job itself was a mix of straightforward removal and absolutely rage inducing re-installation. I did the following removal procedure:
- Take the front side of the OTE pipe off and shifted the pipe out of the way. Stuff hose with shop towels and secure hose out of the way.
- Disconnect the air box from its mounts and disconnected the hood intake from the box.
- Disconnect the pipe from the throttle body. Stuff pipe with shop towels and push pipe towards the front of the car to get it out of the way.
- Cover the starter with a shop towel.
- Remove the throttle body mounting bolts from underneath the car with 1' or so of extensions on a ratchet.
- Break one of the clips while trying to remove the plug (I wouldn't recommend this part of the step). When removing the plug, I would use two small screwdrivers. One to wedge the plug tab over the nub, the other to pry the plug off. Once you get one side, do the other. Remove plug. Do not break clip! :mad:
- Slide the throttle body out by pushing it towards the driver's side along the throttle pipe. I was able to remove it in in the space left by pulling the hood intake tube out of the way and adjusting the airbox towards the passenger side.
Installation procedure (the fun part :facepalm:):
- The best way I can figure to get this back on with the gasket in place is to have two people. I'm pretty sure it's the only way I got it done.
- Put the gasket on top of the throttle body and put the front passenger side bolt through the throttle body.
- Locate the hole for the front passenger bolt. Hold throttle body up while simultaneously trying to thread bolt.
- If you can get this bolt even kind of threaded (just enough to hold the gasket in place at that corner) then this is where the second person becomes super helpful.
- One person, over the car, should hold the throttle body in place and make sure the gasket stays in place. The second person should reach the string of extensions up from the bottom with a bolt in the socket and try to thread a second bolt (CRITICAL not to strip threads here - I recommend not attaching the ratchet and just using your fingers to manipulate the extensions). Once you have two in place and the gasket is in place, then the rest are easy. I would remove the first one (after getting the other three going) and reinsert it to make sure you didn't accidentally start it wrong.
- Once the throttle body is secure, just reverse the removal steps and you're golden.
Edit:
There is an initialization period required. After installation, turn key to position II and wait for 20 or 30 seconds. You'll hear it sweeping back and forth. Once this is done, you're ready.
Were you able to program the new ETM to your ECU with VIDA?
That ETM doesn't require programming, only initialization in VIDA.
It's a throttle body, not an ETM. ETM is from the generation before the P2R. The throttle body did not require programming. Plug and play. :thumbup:
Big thanks
Sent from my XT1585 using Tapatalk
1 - 8 of 8 Posts
