1 - 6 of 6 Posts
Starts in Great Britain, Stops All Over The World
EBC Brakes are proud to become a Vendor for the Swedespeed community. We are here to assist with any brake questions or application issues, generally anything brake related so let us know how We can help.
EBC Brakes’ Range of High-Performance Automotive Braking Products
When it comes to performance aftermarket braking components, there aren’t many names that are embedded as deeply into the scene as EBC Brakes.
EBC Brakes is an independently owned and managed brake manufacturer, employing over 400 people across the UK and US, and produces the world’s largest range of brake pads and discs for virtually anything with wheels.
Supplying some of the best-selling ranges of brake discs and pads for the majority of cars, EBC Brakes is a solid choice when it comes to improving your Volvo’s stopping power.
Below is an overview of some of the key braking components we supply.
BRAKE PADS
EBC Brakes Ultimax Pads
OEM-Replacement Pads
  • Factory-replacement pads offering improved stopping power at a lower price point
  • Superb daily driver capabilities
  • Work well in all climates
  • Feature ‘brake-in’ surface coating for instant, safe braking after install
  • Ideal for: daily road driving
EBC Brakes Redstuff Pads
Ceramic Low-Dust Pads
  • EBC’s ceramic formula designed to keep dust levels to a minimum
  • Up to 15% braking improvement for road driving
  • Minimal disc damage characteristics
  • Ideal for: prestige and high-performance road cars
EBC Brakes Yellowstuff Pads
Ultimate Street Pads
  • EBC’s flagship fast road and light track pad for all higher-powered cars and SUVs
  • Excellent cold bite and high temperature fade resistance
  • Drastically reduced stopping distances compared to OE equivalents
  • Progressive braking with unparalleled pedal feel
  • Ideal for: fast street driving and occasional track days
EBC Brakes Bluestuff NDX
Fast Street/Endurance Track Pads
  • Fastest street, endurance race and track material with highest friction from cold
  • Road legal for some European markets which require ‘NDX’ suffix road legal pads, but all other markets can use Bluestuff on road with excellent results, since unlike most race materials, this formulation has fantastic bite from cold
  • Surface scorched to eliminate ‘green fade’ and reduce bed-in time
  • Ideal for: fast street driving, track days and endurance racing
BRAKE DISCS
EBC Brakes Premium Brake Discs
OEM-Replacement Sports Discs
  • Acclaimed range of high-performance solid, grooved and drilled brake discs
  • The perfect way to complement EBC’s high-performance pads in your vehicle’s factory-caliper brake setup
  • Ideal for: spirited road and occasional track use
EBC BRAKES RACING COMPONENTS
Formed in 2015 as a response to the ever-expanding track day and race car markets, EBC Brakes Racing is a sub-division of world-leader in the industry, EBC Brakes.
EBC Brakes Racing aims to offer uncompromised braking products of the finest quality that offer unparalleled levels of performance on track days and in race situations.
EBC Brakes Racing RP-1™
One of EBC’s Most Extreme Brake Pad Formulas to Date
  • Superb modulation gives unprecedented control and feel throughout each braking event
  • Extremely low wear rate with stable friction coefficient, even under the harshest on-track driving conditions
-Pads come thermally bedded, eliminating ‘early-life’ fade and minimising bed-in time
-Stainless-steel backing plates reduce heat conduction, lowering caliper operating temperature
- Ideal for: track/race driving in lighter, heavily-servo’d cars [NOT ROAD LEGAL]
EBC Brakes Racing RP-X™
High-Performance Motorsport Race Pad
  • Extremely high friction coefficient across the entire temperature range
  • High initial bite and impressive brake power, all with reduced pedal effort
  • 100% brake effect from cold
- Ideal for: race/sprint driving in heavy, high-powered vehicles [NOT ROAD LEGAL]
EBC Brakes Racing 2-Piece Fully Floating Discs
High-Performance Two-Piece Replacement Discs
  • Fully floating design with all-aluminium hub to significantly reduce weight
  • SG grooves, directional curved vanes and SD-Drive bobbins for optimum track day/race capabilities and longevity
  • No vehicle modifications required with most applications
  • Ideal for: track day/race driving
EBC Brakes Racing Apollo Balanced Big Brake Kit
One Giant Leap for Braking Performance
  • Full ‘balanced’ kit featuring Apollo front calipers and other components for both front and rear axles
  • The ultimate upgrade when it comes to stopping power
  • Supplies a firmer and more responsive brake pedal feel
  • Complete with 2-Piece Fully-Floating Discs, various pad options, lines and fluid
  • Ideal for: fast road/track/race driving
GET YOURS
Shop the full range of EBC Brakes components at Where to buy EBC Products - EBC Brakes
BRAKE PADS
BRAKE DISCS
GET YOURS
View attachment 121432 View attachment 121433 View attachment 121434 View attachment 121435
How well do the slots hold up to corrosion? Are they double disc ground? What type of corrosion coating do you use?
Reactions: EBC Brakes UK
Hi, We use our thermic black coating. This does rub off with use on the friction faces, but remains on the hub and outer edge. Thanks
EBC yellows are ECE Brake safety tested which means they must work perfectly from cold at least as good or better than stock pads.
When Yellowstuff see some heat (which is not tested for in the ECE R 90 brake safety regulations) they really show their pedigree. On Japanese cars built with lower friction FF rated pads these deliver a full grade higher stopping and on German cars built with GG these are about the only aftermarket pads that will match or beat the pretty good German OE spec pads and that takes some doing.
A TRUE PERFORMANCE PAD THAT ALSO HAS A GOOD MANNER ON THE STREET
High efficiency performance and race brakes for track & street use, fast to bed-in, great for street vehicle brake upgrade.
Not only a high friction pad but very resistant to heat and loads of heavy braking means that yellowstuff has been used with great success in race cars and on high speed Police Vehicle brakes alike.
EBC Yellowstuff pads are used on the UK Silverstone Race Track Drivers experience cars because of their high performance and longevity. Yellowstuff also claimed a win in the Targa rally and for two years running in the Brazil Mitsubishi off Road Team Desert Challenge.
Because of its huge heat range, the applications where EBC Yellowstuff will deliver benefits range from fastest street use on higher horsepower cars and race use on most street based cars and even as a brake upgrade on Trucks and SUV. Yellowstuff is especially appreciated on Trucks for towing and heavy loads and where wheel and tire oversize upgrades have been fitted. In longer races EBC Bluestuff NDX or the new EBC Orangestuff grades should be considered.
122062
Best brakes so far since working on cars beginning in 1978.
Photo is of 08 C30. Kit came from Amazon with no instructions so I sprayed and removed the black coating which I thought was special coating for shipping. Regardless excellent stopping. Have a set of EBC brake pads on the rear of an 03 Odyssey with new generic rotors. More braking in rear less dive in the front when braking. Very nice!
126074
1 - 6 of 6 Posts
