Hi guys!
2007 V8 owner. I have bought a licence plate mount and two 7" LED lightbars. I have never tried anything like this before and I'm wondering if there is an easy way to wire these so they come on with my high beams? (xenon HID lights).
Thanks!
If you have ABLs the high beam is a metal shutter inside the D1S bulb and the inner H10 are solely used for daytime running lights, at least that's how it is on my '08.
Got a few switched options https://forums.swedespeed.com/showthread.php?230021-Anyone-add-any-auxiliary-lighting, https://forums.swedespeed.com/showt...it-Installation-Instructions-Part-Numbers-Etc. , https://forums.swedespeed.com/showthread.php?604685-Engine-Bay-Switched-12v-Options , might be a couple more if you expand to other Volvo centric sites.
Suppose there's a way to make it work when high beam is engaged either via LIN tap or electrical connection inside one of the HCUs to a trigger a relay if you're stuck on that scenario.
