1 - 8 of 8 Posts
hi does somebody have a dumpvalve on their v50 t5
i mean a after market one
like a hks of a forge
can somebody give me a manual for in stalling it
what i mean is the one with the nice sound
thanks
greetings from holland ;)
Forge FTW
It's a pain to install - I got a garage to do it!
Sounds good esp with a K&N intake.
Yep, I do. There isn't really a guide since with universal products they can be plumbed into the system anyway you want. Mine in particular is welded onto the side of my aluminum intercooler. Anywhere you can plumb it into the charge piping will suffice.
http://forums.swedespeed.com/showth...ie-fabrication-custom-S40-Intercooler-project
For this to work properly, all you did was disconnect the vac line from the cbv and use it on the bov right?
Sent from my iPhone4S using Tapatalk while on the toilet.
No, actually just used a T fitting and plumbed right into the same vacuum line. I run the stock cbv and HKS I'm sequence. To disconnect the vacuum source from the stock cbv u need to remove it and install a block off plate.
I see that works perfectly fine then. Thanks Kyle. Infant wait to get your intercooler now. The next step for me into find a legit place to get a real hks
Yeah it sucks HKS packed up and left the US market, going to make getting parts in the future tougher.
1 - 8 of 8 Posts
