1 - 11 of 11 Posts
Dropped my car off today to get cleaned out. Mainly have the carpets cleaned really well and that good stuff.<p>Just got a call from them saying that the seat is ALL THE WAY FORWARD and they can't get it back. Seems the fuse keeps popping (tried a couple apparently).<p>I've never had this problem. Any takers on what it is or what to look for? I'm 6'4" so I'm going to have to fix this problem before I can even get IN the car.<p>
Re: Drivers' Seat Short? (Rues R)
Damn, that sucks, stick a paperclip in the fuse holder just to get the seat back if you have to, just to get home. <p>Did they shampoo the carpets or use anything that might have gotten moisture where it shouldn't be?
Sounds like a short or something. Could they have spilled water or some other cleaning liquid on the control?<p>-Eric
Re: Drivers' Seat Short? (Sue Esponte)
I suppose its possible they spilled some cleaning agent on the control. One would think that the most reputable place in town would be good about electronics on power seats etc.<p>I just took the car for service yesterday, and had to adjust the seat when I got it back, so I KNOW it worked.<p>Hopefully she will snap back to life...because I really don't have time to get it into service as I'm leaving on Monday for a LONG roadtrip...
Re: Drivers' Seat Short? (Husker Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Husker Z</b> »</i></TD></TR><TR><TD CLASS="quote">Damn, that sucks, stick a paperclip in the fuse holder just to get the seat back if you have to, just to get home. </TD></TR></TABLE><p>Please do NOT follow this advice. Unless you like a melted fuseblock, destroyed harness etc etc.
Try this....<p>Replace the fuse, try to adjust the seat other than sliding it back. If all other functions seem to work then check the tracks out closely to see if there's a coin or something jammed in there preventing it from going back, and popping the fuse.<p>If there is something jammed in there it would not pop the fuse instantly. Would take a few seconds.<p>If it pops instantly then yes, there is a dead short somewhere and my guess is right at the seat since that is the area they were working.
Where did you take your car?
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote">Try this....<p>Replace the fuse, try to adjust the seat other than sliding it back. If all other functions seem to work then check the tracks out closely to see if there's a coin or something jammed in there preventing it from going back, and popping the fuse.<p>If there is something jammed in there it would not pop the fuse instantly. Would take a few seconds.<p>If it pops instantly then yes, there is a dead short somewhere and my guess is right at the seat since that is the area they were working.</TD></TR></TABLE><p>coin will not blow the fuse. as soon as movement is blocked by something, the relay should switch off the motor..<br>still hope you have coin there though. I personally ran into this twice (on different cars).
Re: (Papa_Kirlo)
Not sure what was up with it. Couldn't even get a fuse in all the way, and it was blown. ALWAYS HOT.<p>So I pulled all the connections from the control unit, looked at and straightened all the wiring, then reconnected one at a time...and voila, no more short. Got the seat all the way back to where it needs to be. <p>Still need to check the wires again to make sure none of them have any bare spots, but the seat it working again.<p>Needless to say, still a bit confused as to why it did this. <p>Oh the R and its quirks! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0">
Definitely dig into it sometime when you have the time. Something is shorting out for sure.<p>Make sure to disconnect the battery as you will get an airbag light if you mess up.
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote">Definitely dig into it sometime when you have the time. Something is shorting out for sure.<p>Make sure to disconnect the battery as you will get an airbag light if you mess up.</TD></TR></TABLE><p>Maybe I will just disconnect the power seat. This way I have a valid reason for not letting anyone sit behind me haha
1 - 11 of 11 Posts
