1 - 2 of 2 Posts
I went to replace my transmission axle seal for the driver side on my 2005 s60r. I used a punch and hammered it on one side. It popped out but i think part of it is still stuck inside the transmission part. New is on left. https://imgur.com/a/HNVgiPM
Is the new seal not going in properly? Does it appear that something is still in the hole??
**If the metal re-inforcing ring is stuck inside then you can take an 1/8th inch drill bit, cover the head of it with grease and drill a hole into the ring, use a pocket screwdriver in the hole to help wiggle/coax it out. Rinse out any debris and wipe off the surfaces.
1 - 2 of 2 Posts
