Before you start pulling fuses, try this simple method first:
1. Gently raise the front section of the button to close the window and hold it for one second.
2. Release the button briefly.
3. Raise the front section of the button again for one second.
If that doesn't work, then you'll have to do the fuse pull method (your owner's manual should indicate which fuse it is):
1. turn ignition to on. (Do not start motor)
2. Hold tool ready to pull fuse.
3. While running window down, pull fuse. Window will stop about 1/2 way.
4. Turn off ignition & replace fuse.
5. Turn on ignition & bring window the rest of the way down by holding swithch.
6. Bring window all the way up & continue to hold swith in up position for 5 seconds after window has closed all the way
It's pretty easy and only takes a few minutes to locate the fuse and run this procedure. You won't break or reset anything else, as long as you pull the right fuse :D
