Is it possible to tighten the mirror? It is bouncing all over the place when I accelerate. I looked at an exploded view of the mirror and can not understand how the mirror housing attaches to the pivot of the pillar bracket.
Do I need to pull off the Temperature sensor to gain access? If so, do I pry it off and should I unbolt the mirror from the door pillar first?
Thanks
Your mirror glass is getting ready to fall off, it needs to be removed and glued back on ASAP. You should be able to just pull the glass off.
