Endless problems it seems with this car... opened the door last night, got in and then door wouldn't shut. Kept trying with no luck. Had the door apart this morning but no idea how to pull the lock out to see what's wrong with it. Anyone have this issue before?
Happened to me yesterday, and a few years ago if i recall correctly.
You just have to open and close the door dozens of times until it starts working again, try firm closes with an extra little "oomph" right before the door closes shut.
Once it starts working again try a few more times until it doesn't fail anymore. It's most likely due to cold weather but could be an electronic thing :S
There is a repair bulletin on this problem. It is indeed due to cold weather. I might add that it only applies to 2004-2006 so they must have changed the lube type in the newer cars. Replace the latch if it's totally trashed.
DESCRIPTION:
In certain winter weather conditions a door lock may become frozen. The door can be opened but the pawl may not be moving freely and does not return easily. As a result the door may be hard to close or may bounce back.
SERVICE:
When a lock mechanism is frozen it must first be defrosted in order to move freely again. Let the vehicle sit inside to defrost. NEVER USE ANTI-FREEZE SPRAY! Anti-freeze type spray will remove all lubricant along with the ice and the lock will become very sensitive to water intrusion thereafter.
Once the lock is defrosted and is moving freely again, slightly lift the claw to open a passage towards the pawl bearing area. Use lubricant (P/N 1161827) with a nozzle pipe attached. Insert the nozzle pipe into the passage and aim upward towards the pawl bearing area. Spray for a few seconds.
Here's the best I can do with low res pics. I think you get the jist of it. Aim carefully... Sticky?
