Hi Guys,
Just had a custom 3 inch downpipe and exhaust installed on my R with 75,000 miles. Went with a 3 inch custom downpipe to a magnaflow resonator to a borla xr-1 ending with the elevate tip. Sounds great over 3000 rpm but has some drone around 2000 rpm. Also seems louder when I’m off the gas than on. Overall car is quicker and turbo does spool faster.
Having a couple issues:
1. Getting a code for P0134, Oxygen Sensor, Circuit no activity Detected Bank 1 Sensor 1.
Car seems to run fine, no loss of power. Installer advised cleaning the MAF? This is for the front O2 sensor right? The rear one is in a 90 degree spacer. What’s the next step, replacing the front sensor? Any guidance is appreciated.
http://forums.swedespeed.com/showthread.php?158841-Quick-O2-Sensor-question
2. Now I mistakenly assumed that the elevate tip would fit the body kit. The installer ended up cutting the driver side lower exhaust trim piece to get it to fit. I think the sport kit on my car is from a regular S60 and not the R kit. The difference being that the S60 kit has the smaller oval exhaust hole and the R kit has a larger more rectangular hole. Is this correct?
Whats my solution here? Can I buy just the 04 R version of the driver side exhaust trim piece with the larger more rectangular hole to accommodate the elevate tip? On the 04 R kit, is the piece with the exhaust hole separate from the center rear section, or is just the passenger side rear no hole lid the the only separate piece? It looks like part number 39992442 is just for the passenger side rear panel without the hole. Does anyone have the part I need or can point me in the right direction to find it?
My posting permissions don't allow me to post pics. The exhaust trim that was on the car is the same as the one in Lowenharts post #17 pic on this thread:
http://forums.swedespeed.com/showthread.php?117317-anyone-interested-in-OEM-S60R-sport-body-kit
The trim piece with the larger more rectangular hole that I need to fit the elevate tip is this one shown here on DevolvR post #25:
http://forums.swedespeed.com/showthread.php?163106-Racing-Bodykit-for-S60R
