1 - 10 of 10 Posts
· Registered
Alright, my 45,000 mile service is right around the corner. Seeing the popular topics on the forums, and taking into account my "spirited" driving style, I want to take preventative measures to make sure various mechanical things DON'T blow up in my face. Here's my current list of things to have checked, please let me know if I've missed anything glaring or otherwise, AND how I should phrase these questions for the service department so I seem "knowledgeable"... http://********************/smile/emthup.gif
Check angle gear
Check collar gear
Check Haldex AWD functionality
Check life on brake rotors
Check life on torque converter
Flush transmission
Check alignment, balance and tire tread
Raise headlights
TIA
· Registered
Re: Double-check before I schedule service... (m3nt0s)
Don't know how you plan to do a couple of those, have fun
· Premium Member
Check angle gear (just check for leaks at the flange)
Check collar gear (skip this)
Check Haldex AWD functionality (Just have them run general codes)
Check life on brake rotors (Ask how much life is left on them)
Check life on torque converter (skip)
Flush transmission (Try to find a independent mechanic for this due to $$$)
Check alignment, balance and tire tread (Easy)
Raise headlights (Turn adjustment and have them check for proper SUM calibration)
· Premium Member
Re: Double-check before I schedule service... (Helmut Ranff)
Quote, originally posted by Helmut Ranff »
Easy if you think driving on a flat road shows proper alignment.
Put it on the rack and get real numbers.
· Registered
i'd like to see a mechanic "check" the alignment for you.
considering they have to bolt up all the equipment to see if the car is aligned properly, it seems there is no such thing as "checking the alignment." which means you're paying for one lol
· Registered
Re: (TGO)
Yea checking alignment and performing alignment are pretty much the same.
You can raise the headlights yourself. Look behind each headlamp looking down into the engine bay for a single white 6mm hex nut. Turn CCW (I think) to raise. If it doesn't raise anymore, then you're out of adjustment room and you need to turn them down, get a SUM recal, then raise them back up.
· Registered
Quote, originally posted by m3nt0s »
Check collar gear
Good luck with these. Brake rotor life is subjective and the others will require lots of labor hours. You may want to consider other fluid changes such as coolant, brake, differential, angle gear, etc. Simply beacuse of age, I had the coolant, PS, and brake fluid done and will have the others taken care of at the next service.
· Registered
Also, have them check the loose nut behind the steering wheel. Very common these days! http://********************/smile/emthup.gif
· Registered
PROCEDURE:
1. Go to empty parking lot or be 1st in line at a set of lights while red.
2. Turn DSTC off (5 click off, not reduced).
3. Put car in Advanced mode.
4. From a stop, nail it at WOT throughout 1st gear.
RESULTS:
A) If car moves forward with all its might, AWD works fine
B) If car smokes front tires, AWD is not working
· Registered
Come up here to Maine and drive in the snow....you'll know if it's working or not.
1 - 10 of 10 Posts
