I had a little mishap installing my door pins. Need to get the driver side door panel off. Anyone know how to remove it? Thanks!
Re: Door panel removal... Anyone have some instructions? (travist206)
LOL, I had the same problem. Super easy thing to remove. Here is the basic stuff you need to do:<br>-remove the door trim piece (aluminum, plastic, fake wood, etc). It basically pops out of it's spot.<br>-remove the 2 (or 3, can't remember right now) torx screws that hold the panel to the door, they are now visible because you remove the trim.<br>-now pop out the door panel by going around it with something that won't scratch the paint job or damage it. There are 7-8 clips/fasteners that you need to remove.<br>-carefully remove any of the electronic wiring and the handle cable if you can't get to the door pin issue without going further.<p>Hope this helps, I may have forgotten something but it gives you a good start. Doing the whole thing blindly would be much worse. I believe there is a write up that kind of covers this in the stickies for the forum, something about removing tint and EDIT: here it is...<br><A HREF="http://forums.swedespeed.com/zerothread?id=96923" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=96923</A><br>...good luck!<br>
Re: Door panel removal... Anyone have some instructions? (carreragt7)
THANKS!!! My 15 minute door pin project unfortunately turned into a 2 hour project but It was a great learning experience! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
