My 94' 960 recently started making the noise that indicates that the driver side door is open whenever the key is in the ignition. So far ive just cranked up the radio to drown it out while i drive, but i would really like to find a quieter solution. is it just the sensor in the door jamb or is it something more complicated, and has anyone else had this problem?<p>thanks.
Re: Door open sound wont stop. (daytripper)
I'm assuming the dome lights aren't on (they do go on and off when you open and close the door, if so the door switch's are ok). I couldn't find the alarm in my old manual but I'm guessing they used the seat belt warning relay to do this also. It's the big rectangular relay in the fuse block, Try and unplug it and see if that stops it.
