1 - 6 of 6 Posts
Today I noticed that my wheels started to spin more.<br>My tires are still new,dstc active.<p>Can there be any problem with anti spin system or something else?
Re: Does your wheels spin when fast start up? (xenophobic)
you may have a failed angle gear. Regardless of state of traction, or Haldex... the prop shaft should move when the front wheel(s) do. You can check this on a lift.<br>
Hmmm... I seem to get a lot of tirespin on moderate -throttle takeoffs too... I'll have them inspect the angle gear next time i'm in.
Re: Does your wheels spin when fast start up? (JimLill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JimLill</b> »</i></TD></TR><TR><TD CLASS="quote">you may have a failed angle gear. Regardless of state of traction, or Haldex... the prop shaft should move when the front wheel(s) do. You can check this on a lift.<br></TD></TR></TABLE><br>Jim,I couldn't find a lift in that time,but I found a street with lots of sand/dust on <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> ,and saw that the front and rear works and spins well.<p>Tomorrow I will go to dealer and will say them to check.
Did either of you get any fix to this problem?? Mine is spinning the front wheels and lots of torque steer all of a sudden over the last week.
Re: Does your wheels spin when fast start up? (LOTR)
check out the conclusion of my wheel spin issue <br><A HREF="http://forums.swedespeed.com/zerothread?id=65699" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=65699</A>
1 - 6 of 6 Posts
