1 - 6 of 6 Posts
I posted earlier looking for info on the warm starter valve since it is causing the #13 fuse to blow in my '90 240DL wagon. There really doesn't seem to be any effect on performance or starting caused by this problem, however I am curious about this warm starter valve. I know there is a cold start valve...could this be the same thing?
Re: Does anybody know what the warm starter valve is? (ncrisafi)
Is it on this diagram?<p><A HREF="http://pliki.mojevolvo.pl/schematy/volvo_240__1990.pdf" TARGET="_blank">http://pliki.mojevolvo.pl/sche...0.pdf</A><p>George Dill<p>
Re: Does anybody know what the warm starter valve is? (gdill2)
Sorry, its not on there as far as I can tell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ncrisafi</b> »</i></TD></TR><TR><TD CLASS="quote">Sorry, its not on there as far as I can tell.</TD></TR></TABLE><p>Nor is it anywhere else - no such animal on a '90 240.<p>Here is the cold start valve which may affect a hot start if it is faulty...<p><A HREF="http://www-b.autopartswarehouse.com/sku/Volvo/240/Bosch/Cold_Start_Valve/19901993/W0133-1819893.html" TARGET="_blank">http://www-b.autopartswarehous....html</A><p>...or if the valve O-ring is not sealing properly.<p>George Dill<p>
Scroll down on this...<p><A HREF="http://www.autoelectric.ru/auto/volvo/740/1989/740-89.htm" TARGET="_blank">http://www.autoelectric.ru/aut...9.htm</A><p>...to locate your car's fuel system then check out the wiring for cold start, hot start, etc.<p>George Dill
Hmm...thanks again for the info...I guess it could be the cold start valve...but since the car is running ok and that's an expensive part I guess I can hold off for a while. Also, I'm afraid the wiring diagram wasn't quite right as it is for a 740...so different fuse system I think.
1 - 6 of 6 Posts
