Hi,
My head light are pointint too high.
Does any one know how to relibrate the self-leveling headlights?
Thanks
I know you can adjust them with the leveling knobs on the top of the headlight itself or maybe through VIDA/DICE.
Locate the self leveling motor at the back of the headlight housing, there's a white 6mm looking hex bolt/adjuster that's clearly visible.
Yeaaaaaa what he said :D
The above all describe the manual, mechanical adjustment. If it's still screwed up after that, you'll need to recalibrate the SUM...something your friendly stealership can do...as well as someone with a DICE/VIDA setup. It's one of the primary reasons I bought mine. :)
And if all that doesn't work, level it manually and pull the plug to the motor.
