Status
Not open for further replies.
Banned
do88 was founded entirely from scratch by two young entrepreneurs and has in addition two employees at this date. We are selling self-developed, custom made silicone hoses, intercoolers and pipe kits with accessories. Our goal is to provide immaculate quality, unique assortment and speedy deliveries.
Our all aluminum radiators is entirely developed by us in Nykvarn, Sweden. One could easily be misled to believe all aftermarket radiators are the same. That is not the case. To reassure fitment, finish and quality we have chosen to carry out this process ourselves. It is simply better. Moreover, this allows us to control our supplies and develop new products without third party intervention. Fabricated in top quality aluminum with CNC-machined brackets and connections, our radiator withstand high temperature and pressure for a long time, thereby guaranteeing functionality for you and your vehicle. The shiny, polished surface has to be considered a bonus!
For sale is this do88 Volvo S60 R V70 R S80 99-08 NEW Radiator
do88 all aluminum performance radiator for Volvo S60 R V70 R S80 99-08.
This radiator fits all models with manual or automatic transmission, both turbo and naturally aspirated cars. It´s an entirely new product with improved design. Matters as fitment, finish, quality and performance is constantly being challenged and questioned to make sure that we´re always up front. Buying a do88 product means that you can and should expect it to be as good as it ever could be, hence our revision and redesign of this product, along with many others.
Made in a 100% aluminum construction with 40 mm thick core with only 6 mm tube spacing, compared to the OEM that has 8 mm.
Note!
Do only use OEM Volvo premixed glycol, or concentrated mixed with distilled water when installing this radiator.
If your car has other glycol today, then make sure to flush your system thoroughly before changing to the OEM Volvo glycol.
If this has not been done on your car we will leave no warranty on this radiator.
We are to receive this product in a few weeks, but choose to announce this now already as the demand is high and the inquiries keep coming in. Sign up today to make sure to get yours!
Fits:
- Volvo S60 / S60R 2001-2008 manual gearbox
- Volvo V70 / V70R 2001-2007 manual gearbox
- Volvo S80 1999-2006 manual gearbox
- Volvo XC70 2001-2007 manual gearbox
- Volvo S60 / S60R 2001-2008 automatic gearbox
- Volvo V70 / V70R 2001-2007 automatic gearbox
- Volvo S80 1999-2006 automatic gearbox
- Volvo XC70 2001-2007 automatic gearbox
Item price 486 USD!
Please feel free to contact us at [email protected] , or go right ahead and order your radiator at any of our partners:
http://www.eeuroparts.com
http://www.eurosporttuning.com
http://www.vivaperformance.com
http://re-volvparts.com
anyone have any thoughts oh this, or similar replacement products?
Banned
What is 100 %? If it excludes bending, fiddling and winkle the surronding parts to get it in place, then no. But that is not the case with any radiator either, not even stock. It´s tight to get the rad in place, regardless of the manufacturer behind it.
Your reply does also suggest we have welded on our own tanks on an existing rad. That is not the case. The core is caringly chosen by us to match our demand, and the radiator is completely designed by us.
This is a performance upgrade, not just another aftermarket replacement with stock-alike performance.
Regards,
Isak, do88.
Personally, after almost loosing a newly rebuilt transmission the day after installation due to a failed radiator end tank (thank god that I had installed a seperate trans cooler), I can appreciate aluminum end tanks instead of the stock plastic ones.
My question is: Is this product primarily just for peace of mind? Have you compared this unit's performance against a stock unit when towing? What about high hp applications? What maximum hp can this reliably support?
Banned
Hello sir!
Yes, it´s primarily for peace in mind. Bursted plastic tanks can have devestating consequences - as you mentioned. It wouldn´t seem fair to just make it more reliable though. Therefore the tube spacing is 6mm on our piece instead of 8. This means it will absorb heat better, as there´s more friction for the fluid to cross where the cooloing fins will hit it. Perhpaps it doesn´t sound much, but 25% off (8mm vs 6mm) will make a difference. We have not been able to record any logging data but it´s certainly more effective.
Regards
Isak, do88.
Status
