1 - 10 of 10 Posts
Also need to verify that they can handle the extra weight difference between the models.
The hub may be the same but offsets widths are different. I don't believe V90 was mean to carry 275mm tires (width is 8" for V90 vs. 9" for XC90).
I thought he asked about V60 wheels.
V90 47mm offset on 20’’
V60 42mm on the large 19’’
Do not see a problem there
But you can stop at the dealer mount one one see if it clears on both front and back.
Also the 20’s on the V90 255-35 on the 19 235-40 so I again see no issue.
Never mind. You want the v60 on xc 90. My mistake. Ignore the above post. I was thought I was in the V90 sub forum.
I mean the V90. I tried editing the title but that wasn't an option.
Basically I want the V90 20" rims on the XC90.
I would check it at the dealer.
I tried that verbally and he replied that it didn’t fit for some reason.
I wanted them instead of my 22” as they look the same and have more rubber cushion.
1 - 10 of 10 Posts
