If I am fitting my vehicle with new wheels and tires (same diameter as previous, but wider rubber), is it advisable to have my alignment done? <p>Oh, and i'll coin an acronym for one time use: SPITS. Search Police* I Tried Searching!<p>*ie: Mullman, UKMatt<p>
Re: Do new wheels require alignment? (Mayor Sizzle)
No alignment is needed for putting on new rims/tires. Alignment is needed only if you are modifying the suspension components (ie, lowering the car).<br>
It's not needed but it'll be ideal. I bought new tires and didn't get an alignment right away. After a long road trip, I noticed unusual tire wear. I went to get it aligned and three tires were pointing in one direction while one in the opposite. Maybe that explains high tire wear on my original.
my logical half says to get a wheel alignment after doing anything major to the wheels or tires...<p>i know some of my friends have had some problems in the long run because of the torque on the lugs. If you're gonna do it yourself, rent a torque wrench or something to make sure you're not overtightening the lugs. That can be big problems.
No alignment necessary with wheels, as was noted. If you needed an alignment with the new you'd need it aligned with the old as well. <p>I switch wheels all the time between street and track - no alignment change required.
