Discussion Starter #1
I know I need to drain the coolant, but won't the oil settle in the oil pan below the turbo oil lines? :confused:
No need to drain the oil. You can drain the coolant down to the midpoint of the block by using the drain port on the rear, saves some coolant.
Curious, you are doing the 16T upgrade right? Did you make your new downpipe for an angled flange or straight flange?
Discussion Starter #4
I made it for the angled flange that is on it already , I can switch the hot side to make it fit.
