Thanks for sharing this PPF DYI! I was planning on finding a vendor to do this until I read through your post on how to do it by oneself. A few questions:
A) How long did it take to do the hood? Front bumper area? How long do you estimate for a beginner?
B) You mentioned applying heat to stretch the PPF for high curvature locations. What type of heat source do you recommend? Hair dryer or something more "professional?"
C) When working with the 3M Pro PPF is there a limit to how many "times" water can be sprayed under the PPF? Is there adhesive on the PPF surface touching the car that can be washed away by overspraying it with too much water?
Before going all-in I might try putting PPF first on the small side mirrors. If that goes well then I'll have some confidence for the larger PPF sheets.
Hi. Sorry I didn't see this post until now.
The side mirrors is quite curved; you might want to try the fender area behind the headlights. Or maybe a long strip along the A-pillar. That is also a useful area to protect.
(A) Excluding thorough washing and drying, be prepared to allocate about morning to noon/afternoon. When all the squeegee motion and amount of pressure is just right, it will be much quicker than that. The most likely reason things go slow is from redoing mistakes.
(B) I use home-grade hair dryer. I have 1 heat gun (pictured), and even the lowest setting can be dangerously hot enough to permanently deform plastic. It is nice that heat gun heats surfaces up faster, but sometimes the threshold between nicely heated to toast can be missed. I've had an ABS piece I was heat forming turn to useless wavy piece because of that.
(C) Depending on the film manufacturer, some recommend a second spray bottle of water with 1-2 small drops of baby shampoo. Baby shampoo because most other soaps have additives that might stay under the film. Soap because it momentarily makes the adhesive not stick to the body panel. So, the way you use it is to spray the entire adhesive side of the film with the water/soap solution, and when you want to work on a particular small area, lift the film and then remove the water/soap with the water/alcohol solution. I've seen youTube videos where they seem to casually re lift the film and re squegee several times; I would try to avoid that.
Good luck
