I'm sharing my pov as a repeat user of clear film for paint and headlight lens protection. I have vehicles with clear film on the front end, and after many years of driving, it is evident that the clear film significantly reduced the scratches caused by small road debris over time. These films have a 5-10 year rated lifespan, so they should ideally be replaced accordingly. But it helps keep the paint in good condition, and also helps the polycarbonate lens of headlights stay clear and free from spider cracks that may develop after many years.
If you've done auto window tint DIY, this is definitely easier. Otherwise, expect to buy extra raw material to redo after the first try.
[Disclaimer: I'm not affiliated with any of the companies that make this product, and only share this from the point of view of a user that have tried several different ones over the years. I'm not implying endorsement. The product name, description, and approximate price is to give others an idea on whether it is a potentially good idea to attempt the DIY or not]
For the xc90, I bought 3M's 4th generation film, labeled as "3M Scotchgard PRO Series", available from many vendors. This has gloss clear surface; there are some I've used before that has a matte clear surface (with a different product name/label). I've used earlier generation 3M product as well as others (e.g. xpel). From a vendor via Amazon, a 30"x108" roll covers more than the width of the engine hood cover (~US$190), and a 24"x120" roll covers the side-to-frontal areas of the front bumper cover (~US$170). I should note that even though this is around the 6th time I've installed clear paint protection film (over the span of 15 years), every time is a new learning experience, unlike the professionals that get to do this on a daily basis. This particular paint protection film is around 8mil (8 thousands of an inch) thick, which is an ideal thickness in terms of ease of install and ability to protect the painted surface.
I also bought a thicker type meant for headlight lens protection. They come in either clear or tinted (black, grey, blue, yellow, etc.). For low beams, it is best to choose clear, and some colors may render your low beam color outside of the legal color allowed by local / country laws (e.g. FMVSS in the US). I bought a 12"x24" Lamin-x branded clear roll via Amazon (~US$30), which, when split into 2, is just enough to cover the headlight lens. Headlight lens films are usually available in the 20-40mil range. Since a headlight's surface is significantly smaller than any of the typical body panels, picking the 40mil doesn't carry that much more installation difficulty, but you get the most impact protection. The xc90's foglight can be covered by a 3"x12" roll with some material to spare. The closest I found was a 2 roll of 6"x12" (~US$25). The colored ones are usually only offered at the 20mil thickness.
So, without any waste due to installation mistakes, covering a little more than what a "stage 1" protection I saw offered by my local Volvo dealer, plus headlights and foglights, costs a little over US$400 in roll materials. The leftovers were more than enough to make small patches to protect the inside of the door handle, and along the a-pillar.
You also need 2 spray bottles (one for the slippery solution, another for the evaporating solution), water from a few bottled water, a bit of isopropyl alcohol (for the evaporating solution), and a drop of baby shampoo (to make the slippery solution). When you buy the rolls, they typically send you a squeegee and a paper cutter.
