Anyone know where I can get a pic by pic walk through? The ones in the DIY sections are more about rotor changes... not much on just pads. Any help would be appreciated! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <BR><BR>
<i>Modified by s40boy at 7:07 PM 7-19-2009</i>
I can't see it being any more difficult than any other car. Just follow that guide. You're going to need a C clamp, and to prime your brakes again when you are done. Shouldn't be overly difficult, especially if you've done a brake job before.
Re: (mofolicious)
Well see... thats the thing. I havent ever had to myself. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>But I want to learn the right way to do it. Ill look up a generic one on bing.com and go from there if no one has any pics... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: DIY: Change Your Own Brake Pads! (s40boy)
There is a guide somewhere. For our brakes, you have to turn and press the piston. Rent the tool from Autozone. Other than that, everything is straight forward.
This thread might be of help<br><A HREF="http://forums.swedespeed.com/zerothread?id=120913" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=120913</A>
<A HREF="http://www.s40forums.freeforums.org/how-to-brake-job-05-s40-t5-w-awd-t24.html" TARGET="_blank">http://www.s40forums.freeforum....html</A><p>shows how to change the pads too...
Remove wheels<br>Unbolt calipers<br>Slide them off<br>Remove pads<br>Push caliper piston in with channel locks<p><br>Remove two bolts for caliper bracket<br>Remove 10mm bolt that holds rotor on<br>Hit rotor with hammer to break free from hub<br>Replace rotor, re-install bolt<p>Re-install caliper bracket<br>Grease bracket where pads sit in place<br>Grease pads on sliding ends<br>Install pads<br>Re-install caliper<br>Tighten bolts <p>Re-install wheels<br>Put beer on ice<br>Test drive to verify pads have set<p>Park car and drink cold beer<br>Congratulations are in order for a job well done thus drink more beer.<p>That about sums it up, as for the pics, i dont have any of those sorry.
