Don’t know. Ask himDoes it have a manufacturer identification of some type? Specs? I would be interested, but going onto facebook is a deal breaker.
Why the cloak and dagger stuff?
So are you saying that I can just remove the amp, and then put in my own? Could you please recommend one? I have the Dolby Logic Pro II sound system and don't plan on adding any subwoofers or changing any of the speakers, I like them. That's groundbreaking!OP - After you remove everything with an orange FO cable, you can use any amp you wish. It really comes down to packaging. In other words, where can you stuff an amp, how many channels do you need, etc.
The seven speakers represent five audio channels: front left, centre, right and rear left and right. Most aftermarket amps and head units do not do Dolby processing so you will lose the center channel.Everyone: Quick Update
Just ordered all the parts from this document. NOTE: I have a lot of other tools (wire strippers, heat shrink, soldering iron, solder, electrical tape, etc.) that I didn't need to buy, so I didn't list them. I will update you as I start building once the parts come in next Monday the 10th. Meanwhile, can anyone please recommend any amps for me? Or maybe certain features or specifications I need to look in one that will work with my specific setup? Again, I have 7 speakers (including center), 6 CD changer, DYNAUDIO, and olby Logic Pro II. I do NOT plan on changing out the factory speakers, just need to replace the factory amp as I have been told. Just need help with this one last part!
Thanks everyone!
Yes, I am aware I will no longer have a CD changer or the Dolby Surround Sound. Will that make much of a difference with vs. without Logic Pro II? I think SwissXC90 said I have 5 channels, so that means I must look for a 5 channel amp. Yes, I plan to power all of the factory speakers except the center unless there's a way to retain it after doing an install like this. BTW, what all am I removing that is MOST-related? Just the CD changer, stock radio, and stock amp, right?If you remove all of the MOST items you will not have Dolby or a CD changer. Yes?
You will have 7 speakers or 7 channels? Do you plan to power all of the factory drivers?
I didn't see a DSP listed. Are you still going with the Sony HU?
How many people typically ride with you?
Still no subwoofer?
Thanks for the info. So how much wattage/impedance should I look for in an amp? That's my main concern, I've ordered everything else but an amp. Should the amp be 5 x 65 W at 4 Ohms? That's what MusicarNW recommended, they recommended the Audiotec Fischer amp here: https://www.audiotec-fischer.de/en/match/amplifiers/up-7dspThe seven speakers represent five audio channels: front left, centre, right and rear left and right. Most aftermarket amps and head units do not do Dolby processing so you will lose the center channel.
Unless you are purchasing a head unit that does surround sound with a center speaker, forget using the center speaker. It would be difficult to find a Dolby Digital surround sound processing headunit that supports a front center speaker.Thanks for the info. So how much wattage/impedance should I look for in an amp? That's my main concern, I've ordered everything else but an amp. Should the amp be 5 x 65 W at 4 Ohms? That's what MusicarNW recommended, they recommended the Audiotec Fischer amp here: https://www.audiotec-fischer.de/en/match/amplifiers/up-7dsp
I just need to know (apart from # of channels, now I know it's 5) how much impedance, RMS power rating, features, size, etc. and other features I need to look for in an amp that would make it compatible with my install. Also, is there a way to retain the center channel speaker? Or one that has Dolby processing?
Thanks so much for the details. I can live without the center speaker, no problem. Is there any way to figure out is 130W is RMS or Peak? Is an amp that supports 5 x 65 W at 4 Ohms not enough? How do I know? I am asking for that specific set of numbers because the experts at MusicarNW said that is the amp that would replace the factory one. This means that the specs on the one they recommended (https://www.audiotec-fischer.de/en/match/amplifiers/up-7dsp) matches those of the factory Volvo one. Please confirm.Unless you are purchasing a head unit that does surround sound with a center speaker, forget using the center speaker. It would be difficult to find a Dolby Digital surround sound processing headunit that supports a front center speaker.
As for the amplifier power, when keeping the same speakers you need to use an amplifier of similar power to what the Volvo amp is. The Dolby surround system does 130W per channel, but VIDA has the full detail.
Here’s a good write up of the existing system:
https://www.media.volvocars.com/global/en-gb/media/pressreleases/5099
And Volvo states in their brochures:
Premium Sound with Dynaudio speakers (V8 only)
The Premium Sound system is in a class of its own. The digital Class D amplifier generates 5x130 watts of music. DolbyPro Logic
II surround sound recreates a sound that’s equally authentic at each seating position. There are 12 high-end speakers specially developed by the Danish specialist, Dynaudio—for the Volvo XC90 and a true concert hall experi- ence. The Premium Sound system includes:
• In-dash 6 CD changer
• AUX input
• 5x130-watt digital Class D amplifier
• DolbyPro Logic
II surround sound with center speaker and digital sound processor
• 12 Premium Sound speakers by Dynaudio • MP3 and WMA compatible CD player
They do not state if the 5x130W is peak power or RMS power (huge difference)
