Hi all so I did a lot of leg work regarding aftermarket radio installs more specifically double din GPS units on XC90’s and found a solution that allows you to remove all parts of thef actory radio. As you may already know there are solutions out there that require certain parts of the factory radio behind.
I found this site company Incartec ( https://incartec.co.uk/Volvo/XC90 ) and they sell all the adapters for the XC90 radio and you can remove every part of the factory radio, over all a little costly and shipping was expensive to Canada but VERY happy. There are no errors and I was able to remove every single piece of the factory radio/amp which meant I had no space issues, getting stuff behind the dash.With by passing the amp I was able to put the new amp under the passenger seat.
This is everything they advised I needed
1 x VOLVO XC90 CANbus Interface - (39-VOL-UNI)
1 x Volvo XC90 (03-07) amplifier bypass cable - (20-307)
1 x Volvo V70 S60 XC90 PDC Interface - (25-509)
1 x Antenna extension 6 Metre - (21-009)
1x Hyundai /Kia Aerial adapter to male din plug - (21-130)
1x VolvoXC90 Radio Facia Double Din kit (50-860)
My car is a 2013 so I would confirm with them parts are the same for other model years.
Important to know that the steeringwheel interface works with the following head unit brands, Alpine, Kenwood, JVC,Blaupunkt, Clarion, Panasonic, Zenec, Eclipse, Grundig, Sony, Pioneer, Becker,
as I wanted to get the Parrot but it is not compatible.
Hope that helps everyone out.I am not sure who else sells this stuff because I looked ALL over the net but if you have an idea please post it will help others out greatly, trust me I spent 2 months looking around.
On a side note as speaker information is also limited onlineI was able to fit 6.5 components in the front doors with a mounting depth of 2.5 no problem (installer said 3” would also be fine). For the rears I was able to fit 5.25 mid ranges with 2.81 depth no problem.
