Hey everybody. I was going to swap out my turn signal and wiper stalks this weekend, but i couldn't find any reference to whether i need to disconnect the battery prior to swapping them or not. Is it required as far as anyone knows?
Yes, if the airbag connections are disturbed and it is on accessory position you'll end up with SRS light lit. Airbag stuff is safest if batt neg cable gets disconnected.
I changed mine without disconnecting the battery. No problems. No lights. Changing the stalks have nothing to do with the airbag or are tied in with each other aside from being located on the steering wheel
