1 - 2 of 2 Posts
<p>Is there a way to DISABLE the standard alarm system on the S40? I ran across two used Volvo S40s (one of which being sold as a certified pre-owned Volvo by a Volvo dealer), and neither of them had a working alarm system. That is, neither of them had an audible alarm when I rolled down the driver-side window, closed the door, locked it via the keyless entry, and opened the door from the inside (ie, simulating breaking a window and opening a door from the inside). Not sure about the LED, as I wasn't paying attention to it. Now, either both of these cars had malfunctioning alarms, or there is a way to disable (and therefore enable again) the alarm? <p>Thanks in advance, <p>Marty
Re: Disable factory alarm system? (martini1179)
have the dealer fix it or tell them to have it working properly before you buy it.<p>Other option is the check the horn fuse or connection. Factory alarm is through the horn so if its not connected, it won't make noise
1 - 2 of 2 Posts
