1 - 2 of 2 Posts
Discussion Starter #1
Bulb position failure along with fading dash. Sigh, time to do the DIM bulb replacement. Does anyone know the spec's of the bulb and - or if a LED alternative is easily and readily available?
So far have had no issues with DIM, however if you see remove the meter, there is some small like bulbs/leds and you could get a replacement from high-end accessories shops, the dealer should have a replacement as well.
1 - 2 of 2 Posts
