Ok....my plans...<p>Electronic digital boost gauge...<p><IMG SRC="http://static.summitracing.com/global/images/prod/large/cyb-a213e351y_w.jpg" BORDER="0"><IMG SRC="http://static.summitracing.com/global/images/prod/large/cyb-a213e161y_w.jpg" BORDER="0"><p>Plus gauge pod...<p><IMG SRC="http://byfiles.storage.live.com/y1p3xxABGXLtbk5-uPjG_2Er0l0Wh1UuDkgLSDZ2iYKXWo0GUsGQZdxSCkAoKx_MkpMBSqqJdIcvhQ" BORDER="0"><p>Plus two of these gadgets...<br><IMG SRC="http://www.partsexpress.com/imageslarge/071-580L.jpg" BORDER="0"><p>2 tappers...one for the seat (switched), one for the headlight (dimmer) (no constant power needed)<p>I will need to extend all of the wires through the door and into the fuse panel area. If i were to run the sender wire through the door, the power and dimmer are seperate from this wire, I would still have to route the power and dimmer back through the door to the fuse panel. The sender wire is quite thick, not sure of the ease to fit both the sender wire and the two seperate wires....please chime in HERE lol.<p>Run the hose through the firewall by the hood release, remove the under panel in the footwell (the panel with the footwell light). mount sender in the same area, and solder the wires at that point.<p>I have read that the pod fits very nicely when the door sail (the cover by the side mirror) is completely removed, so no dremelling there...<p><br><i>Modified by mpdbrown at 5:02 PM 9-10-2008</i><BR><BR>
<i>Modified by mpdbrown at 5:12 PM 9-10-2008</i>
