1 - 2 of 2 Posts
I have very big difference between the driverside and passengerside temperature even if the settings are at the same position.
I have usually have the setting at 22C (straight up) but to make them flow the same temperature I need to adjust the passengerside down 2-3 degrees, or else it flows pretty hot air.
What can be the cause of my problem?
Not sure what the issue may be, my car is the same, never looked into it. Still blows cold when need be, still blows hot when need be, so the temp parts work, just a few clicks off so I deal with it and never bothered.
If you find the issue or fix, let us know, but it's probably not a big thing.
1 - 2 of 2 Posts
