1 - 10 of 10 Posts
Happened to have the undercarriage cover off for an unrelated job over the weekend and I noticed oil all over the cover as well as oil on pan and filter housing. Just changed the oil 4 weeks back and pretty sure undercarriage was bone dry at that time. Wow, is it possible I cracked the housing when I reinstalled? That would be a serious rookie move. Don’t want to waste the synth oil either so I guess I’ve got a make-work project coming up fast as I’m down to the minimum line on oil already. Lovely.
Did you replace the sealing ring? Maybe not installed properly?
Try backing out the filter housing a bit then retorque it. Otherwise dump the oil into a clean receptacle so that you can reuse it and inspect the housing.
I'd also make sure that the sealing ring was installed in the correct groove
Both of my thoughts also.
They do crack. I replaced mine earlier this year after it started leaking a little bit.
Thanks fellas. Will report back.
Always hated those things...rather have a conventional filter.
Take a quick look to make sure you're not dripping around the oil plug. I tried to reuse the crush washer on my last oil change. Mistake!
I make sure the threads and bore where the filter housing is very clean as well as the filter housing as well then liberally lube the new O-Ring & threads before installing the housing. For me it gos in easier than removing it, I keep meaning to put the plastic housing and a good fitting socket adaptor on the spares list, it just seems to be a funky application of plastic and assume waiting to crack.
Regards
Update: that would have been too easy....my ac compressor is leaking.
1 - 10 of 10 Posts
