1 - 9 of 9 Posts
Does anybody know if there should be one or two? I checked today and only one of the remote keys has the blade. The second one was empty. Thanks
I don't know, but it would be very surprising that only one of the remotes has a key blade. I'd definitely go back to the dealer and ask about it.
Each key fob should have a blade inside. You can also verify this in pp. 229-230 of your XC90 Owner's Manual.
thank you nh-ets. It's very helpful. I just checked the box and there is nothing else. As I did not really touch the box since I bought the car, probably the 2nd blade got lost before the box was given to me.
Lesson for future owners = check for both blades :)
Good tip. The blades are separated for some reason. I watched my dealer insert the blades into both key fobs for me. He had to remove the key fob cover to do it.
Your salesmen should have shown both to you. Though I usually show how to open the key fob for them. Had one customer that that pulled the bottom down and broke the latch holding the back side where the batteries are.
Thanks for the heads up!!!! Any other things to be aware of during the delivery process??? I need to start a list!
1 - 9 of 9 Posts
