1 - 17 of 17 Posts
Has anyone had their's repaired after it stopped communicating? Euro mechanic quoted me 3k for a new one, which isn't worth it for me. I found this service on Ebay that says they repair them for just $225. http://www.ebay.com/itm/Volvo-Diffe...Repair-Service-DEM-S60-XC90-V70-/231147446380
Should I be able to just send it in to them then plug it back in when I get it back and then have my AWD back? They have good feedback but I wanted to see if anyone has done something similar with their R. Thanks.
I had seen them montioned and they seem to have a good reputation, though they are about $200 more expensive it looks like.
Has anyone had this done that could comment on the process, results?
My haldex went out this year, we sent it to XemodeX and it costed around 800$ to get a complete rebuild and they offer life time warranty.
Agree to contact xemodex. I have had them fix 2 DEMs (one for me and one for a relative). No problems with either one. They are great, and yes the cost is $450 or so.
And no you can not drive the car with the DEM out. The DEM holds the sensors in place, found that out when I jumped 12 volts to the pump with DEM off, should have seen that was going to be an issue, messy.
Thanks. Was it relatively easy to take out and put back in?
Yes, you can clearly see the haldex when looking underneath and it only takes a couple of screws to get off if i remember its torx screws, be carefull not to damage the interior while removing it its really sensitive.
I was ready to send my Haldex out to xemodex, but after reading thru more posts (this one specifically) I see that there are multiple places that can do the repair service. I see three different companies, Xemodex $400, BBA Reman $225, and ASI $109. I'm sure you get what you pay for? Any input on these places?
I used BBA Reman to repair my DEM without any issues - AWD works great.
Another repair option...
This post is too long, but might save you a lot of time in the long run.
If anyone still has DEM questions, I'd like to share my experience. I have a 2004 XC90 w/254K that recently had the anti-skid message appear. I spent a lot of time in this forum and others gathering info; then troubleshooting and testing. After checking the power, CAN communication and the pump, I determined the board was dead. Most everything I found pointed to either replacing with a new part from Volvo or sending it for repair. My dilemma was that I couldn't be more than just a few days without a car, so Xemodex seemed to be the best option, due to the fast turnaround and price compared to new. But their price; after you factor in shipping is now over $700..... and I felt silly even considering spending 1/2 the car's value for this service.
Then I found ASI.... Great price, but still no response to my inquiries to this day.
Since I didn't know how long ASI would have my board, I decided to hunt for a cheap donor so I could send my DEM in to ASI and still drive the car. I wasn't having much luck keeping the cost less that $60/70. After a few days of searching on eBay, calling local salvage yards, convos w/ my local Volvo-only indy shop, I saw it. It was a comment on eBay. Most of the DEM's on eBay at the time had 1-2 stars... and most of you know why. These don't work on a different car than what they were first programmed to, right? The comment I read stated that if you match the part numbers of the replacement DEM to your old one, then it works fine. Ok, part numbers? There are 6 sets of numbers on my DEM... do they all have to match perfect? When you look at the label, it looks like there is a production date code as well... does that have to match?
So I matched as many numbers starting from the top left. I managed to find an eBay unit with 4/6 matching:
5WP22201 | 05 | 102160
HAP511 | |
I bought it, installed it and the Anti-skid/BCM-0094/CEM-1A64 code were immediately remedied.
$84.42.
This is good stuff. I have those same codes. Assuming I can find an exact match on EBay, is it plug and play? Also anyone had any experience with the IPD Dem cover for added protection?
1 - 17 of 17 Posts
