1 - 2 of 2 Posts
My 2004 Man V70 AWD has got the above DTC from VIDA. There are no others. I looked in the DEM and there are two removeable bits, a pressure sensor and a Control valve/axial solenoid.
I don't think the solenoid is a spare item, I understand you have to buy the full DEM unit. Will a reclaimed solenoid from another v70 work? Can the Solenoid be repaired?
Other have suggested the issue is more likely to be the pressure sensor. comments/opinions please??
I have looked for a fuse which islolates the AOC/haldex, to stop the AWD but have not been able to find one. My rear compartment fuse board only holds 18 fuses.
Am I on the right track thinking the solenoid rather than the pressure sensor is a fault.
Cheers
Bob
1 - 2 of 2 Posts
