1 - 1 of 11 Posts
Your making more sense now, way to take control and get things sorted. You're going to be so much happier when it's all back together and running smoothly. 115,000 is just broken in and despite some worn bushings your car is probably in rather fine shape.
I don't know when your suspsenison was last serviced but it never hurts to look at shock mounts, spring seats, sway bar endlinks while your in there.
PCV is located under the intake manifold and consists of some rubber hoses and a oil trap, you can most likely clean the trap and the lines and be good to go, that is unless the oil changes were overdue and it's filled with sludge.
Your going to save boatloads by doing this yourself or even with a qualified indy shop, just make sure they know what they are doing.
Let us know if you need diagrams or part #'s as many of us have Vadis and willing to help in any way we can.
Hope this helps,
NJGB
1 - 1 of 11 Posts
